Help Please: Need to get my golf flipped on its side
As stated in the title, I'm after a device to allow me to flipp my car on its side within my garrage, there is a fair bit of space but dont want to just roll it onto its side. The car needs to be fully supported as I shall be working on the undercaridge for some time.
Neede asap really as idealy I would like the car ready for this years show season :)
Willing to travel far and wide to collect
thanks in advance
Dan
  • Replies 15
On this programme called 'custom my ride' they had this device which flipped this 1969 dodge charger to do work on the under carriage
I'm not sure what it's called sorry
but look on YouTube and type in custom my ride and look for the dodge charger episode
I hope it helps
Josh
Maybe just get some mates and roll it over gently?
Oh yer
It's has a clamp on one side and a clamp on the other.
It clamps the car and then your can turn the car around 360 degrees
i know what you mean, I've seen them made but can I hell remember the name.
some kinda spit.
try shedition.
Is it stripped to a shell? If it is, get an old matress and roll it onto its side, crude but effective.
^^ i was going to do the old mattres trick but i simply dont have the room to do that, need something to support it so it can then be flipped on the spot
bump
Did you watch Top Gear, not last week, the one before. You need that thing they used to get the Countach into the Art Gallery but can't think of the name!
they are generally called a "spit" we make our own when we build rally shells.
Tbh it might just be cheaper to get a 2 post ramp, although the car wouldn't be on it's side it would make life easier (I hope).
Me and my dad have made our own spits using steel box section, bolts and a bit of arc welding. Think we spent about £60 making it including the box section.
You could try the mig welding forum site , should be useful if you want to make one. Cheers Mark
Dan, I've got a car rotisserie that bolts to the hubs on one side of the car. I bought it for restoring the other Derby with but i don't need it for some time yet. You would need to flip the shell then push it back in to the garage though. It's been used to flip sone heavy cars over the years by the original owner (m2 Jags, etc) so it's heavy duty enough for a Golf.
Drop me a PM if any use.
