6n head unit adaptor
i did ask before i bought it if i would need one but someone told me no, but i do need one. the plug that goes into the back of my new unit will not fit in so i guess i need some kind of adaptor? anyone know where i can get one or which one i need? thanks
  • Replies 30
  • Views 4.1k
you do not need an iso adapter
maybe you have got an aftermarket loom still plugged into the loom
pull it out and see if there is
if so un plug it and plug your new h/u in
i dont understand, I've unplugged my old unit now I've got some cables coming out of my centre console and the cables coming out wont fit into my unit
can you post some pics of what you have in your dash
heres some sorry about the quality.
surely i cant be the only one with this problem
right the reason you cannot plug it in is you appear to have lost the loom for the stereo this is required for the stereo to work without it the stereo is useless
the car wiring is correct that is the standard iso plug
i take it from the picture the stereo is some far eastern dvd h/u
ermm i dont know it was a christmas present :\ and i havnt had the car long so whoever had it before me must have lost that thing you said lol.
is there anything i can do ?
not really i'm afraid can you not contact the person it was bought from to see if they still have the loom in their car or sitting around
what make is the stereo as i may be able to source one depending on the brand
if not then its a new stereo or having a load of cables hardwired to the circuit board
don't you get a wiring loom when you buy the headunit though? :s
usually yes but i believe this was bought 2nd hand
its easily done the person selling it probably did not realise that it was meant to go with it and left it in their car
ahhh didnt realise it was second hand
no i bought it brand new :\ cant i just buy like an adaptor?
i really dont understand whats going on lol, i took my cassete player that is standard in the car out and thats the wires that were plugged into it. but the wires have different types of plugs then on the new cd player? so can i not just buy an adaptor or something :\
you deffo need the loom that comes with the h/u mate.this will have the correct plugs at one end
to fit into your h/u and some other plugs at the other end that will plug into your cars wiring loom
if you put up the make and model somebody may have a spare.
hope this helps.
this is the exact unit theres a pic on there of the back and the wires when you see that you willl get what i mean
if you bought it new then you need to contact the shop you bought it from and explain that the loom is missing
i asked what make the stereo was because i could then tell you if you can get a loom seperately or not
but as it is new it is down to the supplier to send it to you or send it back for a full refund
your original stereo that was fitted to the car had iso connections on the back of it so the vw loom plugged straight into it
aftermarket stereos all have their own style plug but come with an iso on the end of it to plug it straight in
here is an example
http://www.nexxia.co.uk/Car_stereo_spares/...ges/PC3-451.jpg
here you can clearly see that the big plug on the left is the iso which plugs into the car loom the other end has the dedcated kenwood smaller plug that plugs into the stereo
so you need the specific loom for your stereo
Edited by TROUBLESTARTER
sorry but they cannot refuse a refund if the unit is faulty or there are parts missing
it is your legal right as a consumer as the item will never work without that loom
if they refuse to send you a replacement loom then contact ebay direct
it does say that they will exchange a faulty item (at the buyers cost of returning it)
just explain that you need to loom as it is meant to be supplied with it
here is an example
i think they have sent a loom but i dont really know what a loom is, if there is one of those ISO adaper things you were talking about for this stereo i would buy one do you know where i could get one ?
you will not be able to get one for it from anywhere except them i'm afraid
this is the problem with these far eastern units spare parts are not available
if they have sent you a loom then all will be fine plug one end into the stereo the other end into the car job done
no its not like that, there is no plugs that match the ones coming out of my car, if you look on that link and go down to the picture of the back of the player and there is loads of wires coming out with numbers explaining what the wires are for, thats all I've got. and another wire with a plug that i cant see fitting into anything and yellow blue red and black wires coming off it saying batt back ACC and GND
there is no pic of the wires however this may help
if you say you have a plug with a load of wires on it coming out of the back of the stereo then all you need is one of these
http://exclusive-part.com/iso-f_2.jpg
then its just a case of joining the wires together colour for colour
black -black = earth
red- red (use a male and female bullet for this one)= ignition live
yellow-yellow = permanent 12v+(put a male and female bullet on this aswell)
orange-orange = illumination
blue-blue = remote out to antenna
blue/white (if it has it ) leave this as this is the remote amp turn on for amplifiers if you fit them
white-white = front left speaker +
white/black -white/black = front left speaker -
grey-grey = front right speaker +
grey/black - grey/black = front right speaker -
green-green = rear left speaker +
green/black -green/black =rear left speaker -
purple - purple = rear right speaker +
purple/black - purple/black = rear right speaker -
you will have one wire left over for the handbrake this just needs to connect to the black earth wire
so that pic you just sent me.. that is what i have got coming out of the car? so i need to join the wires I've got to them? do i soulder them or anything or just wrap them around?
thanks alot for this i really appretiate it
this is what you have coming out of the car MALE ISO
http://exclusive-part.com/iso-m_2.jpg (ignore the wiring colours on that as vw do not use those colours but use this plug
this is the connector you need to join to your wires coming from the stereo FEMALE ISO
THIS THEN GIVES YOU A PLUG IN LOOM FROM YOUR STEREO TO VW
EDIT: the first picture is what is coming out my car and the second my old stereo. what shall i do
Edited by richhasbigtits
