Polo door handles
Help! Bought my 98 R plate 3 door Polo, and have knackered the driver's door handle and lock (long story)
I have looked at buying a replacement on ebay, but some sellers are saying that vw changed the handles after 96 - is this correct?
Also, where is the gearbox oil top up plug on the 1.9d - it smells a bit of gear oil, and the box looks a bit damp (no whines tho)....
Cheers!!
  • Views 858
Cheers!!
They changed them in 1997 I believe. But they only changed the lock mechanisms and not the plastic handles themselves, if I remember correctly.
If just the handle is messed then any one should fit, I've got one here.
If it's the locking mechanism then it could be a bit more tricky. If the actual lock barrel itself is broken in some way then you're kind of screwed but if it's any other part of the locking mechaism then you should be ok to just replace the bits. I've got a Post-97 handle here with most of the bits on if you would be interested.
Get a photo up of what's busted aswell, would be alot easier to help then!
