Alpine MRP F250 Amp
Hi,
Alpine MRP F250 amp
I bought this to power my 6x9s but change of plans means its no longer needed. This is new and I've only wired it up to check it works. I've lost the box for it but it will be put into a box for postage. There are also two covers which should go over the sides to cover the terminals, but these were in the box. There only there for looks and dont affect the operation of it but this is reflected in the price. The manual for it can be found here http://akamaipix.crutchfield.com/Manuals/500/500MRPF250.PDF
  • 4-channel car amplifier
  • 40 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
  • 100 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
  • 2-, 3-, or 4-channel output
  • Variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
  • Tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
  • Subsonic filter (15 Hz, channels 3 & 4 only)
  • MOSFET power supply
  • CEA-2006 compliant
  • STAR Topology (minimizes internal noise and prevents ground interference)
  • Speaker- and preamp-level inputs
  • Preamp outputs
  • Gold-plated screw terminals
  • Fuse rating: 15A x 2
  • 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
  • 11-1/4"W x 2-3/8"H x 9-9/16"D
  • Warranty: 1 year
More info can be found here http://www.crutchfield.com/S-Tz88sPk0cUi/p...e-MRP-F250.html This can be used to power a pair of speakers and then bridge the other 2 channels to power a sub and has many functions but please refer to the link for detailed specs.
These retail at around £130 - £50 posted
Any questions feel free to drop me a PM or text me on 07825524674
Edited by tomxt99
  • Replies 8
  • Views 282
would the parcel shelf fit a 2000 1.0? cheers
Hi,
Yes as long as its a 6N2 it will fit. I also believe it will fit a 6N aswell but please check.
Tom
What models does the parcel shelf fit in? I'm interested in 6x9s
There 70 quid brand new :S
http://shop.audioimages.co.uk/vibe-qb69-6-...kers-p-430.html
Hi,
The parcel shelf will definately fit all 6N2 models and I believe it will also fit 6N's aswell but please check first. Well the speakers were £150 when I got them but they have since bought out "black" versions and so I can only presume they have dropped in price. Mine are still cheaper though and include postage which is £15 on your link and mine are also new :)
Tom
Edited by tomxt99
They are also advertised on Ebay if you would prefer to buy from there:
Alpine MRP F250 Amp
Edited by tomxt99
All other items sold so first post has been updated. Only the Amp and parcel shelf left!
Tom
I'll give you £45 post right now send me you paypal if your intrested n I'll whip some cash over to you asap :) only pm though as I'm nt on here much thanks
ALL ITEMS NOW SOLD!
