VW polo mk2 hachback being scraped
i have a vw polo mk2 that is going to scrap yard.
recently fitted new fuel tank, exhaust couple months old, engine turns over but does not run.
recently had an accident with ice, crashed into hedge but did not crush the radiator or engine, not able to move as driver side chassis is bent including the door frame and wheel touching the rear of the arch.
i will not send any parts in the post. if you need anything respond or call me 07767755741
i live in torpoint, Cornwall, uk.
You can repair the car as a project, but not advisable as i need it gone quickly (hense scrapyard).
  • Replies 14
  • Views 1.2k
hi mate very intrested in the fuel tank how much? are u able to post?
What CC is this mate?
might be interested in a couple of the bits for a project got going
any ignition bits?
i need coil, amp,loom and dizzy if you have them
cheers
gaz
1043cc
any ignition bits?
cheers
gaz
i have dizzy, lucas and origonal coil, amp and loom are avalable but may take a while to take out, which i do not have the time to take out sorry, and you should also know that i will not post any items.
thanks
Is this a 4 or 5 speed?
4 speed
hi mate is the gear change linkage worn if not pmme
i have taken off the dizzy, origonal and lucas coil, exhaust (backbox), and fuel tank, 4 3-point spark plugs and 3 iradinium spark plugs. all have not been sold yet
Edited by jamhough22
if the carb and manifold are ok ill have them pm me a price posted to pe11 thanks steve
Edited by steveg
Hi mate do you still have the polo? i'm relatively close and i urgently need sections of body to weld into my polo. might even be interested in the whole car to cut up.
Cheers,
Mat.
alright mate have you got the suspension topmount caps also icould do with the front suspension without the springs and shocks ie everything else
hi pal do you still have the ignition system? i.e. dazzy, amp and the loom to go between it if so how much would you take for it all posted?
cheers
gaz
Inlet manifold for sale???
Pm me
