Custom exhaust needed, ramp issues :s
Hi hi!
Basically my car is up sale, but i'm not fussed if it sells or not. If it doesn't i want to completely replace the 'zorst with a stainless jobbie, problem is the custom place i would normally use have drive on ramps as steep as everest, and my car scrapes on camber changes in the road, so you can imagine the problem.
Do you guys know any places in the midlands that do custom exhausts with flat drive on ramps?
Cheers, Dan
  • Replies 11
  • Views 1.2k
Hi hi!
Cheers, Dan
kingswinford tires and exhausts just outside dudley west midlands , why not fit some donk style rims jus to get up the ramps , i used to have to for the mot
i'd love to mate but i cant get anything under apart from the classics, front is on chopped lowering springs
planks of wood are your friend :nod:
scafold boards ftw
mr tyre wolverhampton has a sunken ramp and they specialise in longlife zorsts
get 2 chunky peaces of wood, cut a thick line straight down the middle of them to make them into a kind of fork. jack your car up and when the springs fall out of the top cups slid a peace of wood between the spring and the top cup (this is why you need the cut so it fits either side of the shaft in the shock). once you lower it down your car will be higher x the width of the wood. so if you need it 3" higher used 3" thick wood. it's simple and effective and you won't have to fuck about with your car, just jack it up, slip them in, drive on ramps, do the bizz, drive off, jack up and take off. simples
Pikey as fuck... but I like it!!
I usually use the old turn the music up and get a run up technique :lol:
cheers for the replies guys, i used a shit load of wood at my mates ramps, might have to go with that. i like the run up idea haha, would probably remove all the underside of my car in the process though!
probs making some wooden ramps is your easiest bet as the wood under springs wont do you justice as you wont know the clearance of the exhaust etc,
how much u want for poop again?
those fuckers decided to put mine on the normal ramp...when i came back, i caught them wiping sealer around where my cat meets the manifold from where they had caught it on the ramp.
I've tried that but the music wasn't loud enough :( lol.
Most places who have decent manners will figure out a way to get your car on the ramps. My local garage has specially made add on ramps for such an occasion.
