How to remove black strips?
i want to remove the black strips down the side of the car. i cant remember what they are called and i am not entirely sure how to do it. can anybody shine some light on this matter for me. cheers
  • Replies 12
  • Views 1.6k
Yeah there called bump strips it's been covered loads so you should get some good results on the search function! Hope that helps mate!
Just pull the top part off and then get some gunk on the lower bit to dissolve the glue and they come right off
Hammers usually do the job too.
jimmy'll sort it.
dont do it son, I've tried on the car already mate, well i took off the tiniest bit theres bubbles under there. just to help u out lol. you could get a garage to do it otherwise mate :)
fair enough, cheers for the heads up
haven't done this yet but my mate just used petrol as it eats at the foam glue apparently i plan to use fishing wire as that's how look my rear badges off, I'm not to worried about the condition because i can get it sorted before i paint it.
is there clips on the stripes as well or just glue ?.
just glue on a 6n. Make life alot easier and buy an eraser wheel!
EBAY
Took me about 15 minutes to remove the bumpstrips with a credit card, then about another 15 to get rid of the leftover glue with one of these ^^
i just done mine the other week i`ve done 3 sets before aswell.
i used driving licen to start a edge of then just pulled the strip off nice and slow to try and bring as much glue off that way. 10-15mins for the lot then just used the driving license to carefully srcape the glue off 30mins then a good t-cut and polish and whallah job done as if they where never there.
hope this helps
dan
i did mine dude on my punto yearsssss ago..
Best way to go about it is get a extension cable, your mums hair dryer.. heat up the glue underneath the bump strips, and they come right off with minimal mess left on the door :)
Then abit of warm soapy water... Bobs your uncle :)
P
ye that happened on my old polo, i tuk the one off and it pulled part of the lacquer off the door so i had to stick it back on lol, ide jus pull it off a little bit and check that its not pullin any paint or if there are any bubbles down there, should be alright if your paintwork is in good condition, looks smoooth without them on tho :)
Edited by rob_camo mk4
