filler help
hi all I'm gonna start sprayin my car matt black tom and i need a few scratches filled I'm not to sure weather they need filling but is it jus a case of filling rubbing down to smooth then primer ?↲↲and what you reckon pink steels with matt black car I'm wonderig and would i need to primer me car or jus rub it and spray ? Cheers
i highly doubt they need filling.
i personally would just flat them down with paper and a block until its gone [making sure not to have a hard edge on the under lying layers of primer/paint/etc. and then just give them a quick flick with some 1k aerosol primer and then use soft flatting paper to take down the primer until smooth.
Edited by BigSexyRob
Whether you get them out by rubbing them down or get them out with filler, make sure they're out because matt black will show up any imperfections.
Try rubbing down see if it works :) but if not jus skim sum 3m acrylic stoper putty ova the scrathes should do it.
cheers for the help will see what it come out like tom ?
Knifing putty or stopper on small scratches, and just flat big scratches out with some wet 800. As for your question about priming, i personally would, but with good prep and and 3/4 coats of matt black its should last quite a long time. If you are using filler, prime those parts and areas where bare metal are exposed, other wise youll be asking for problems.
Edited by evabot59
yeah i started doing me new wing and its coming ot good all i did was rub it down and spray i done about 4 coats at the moment so i will see apart from tht jus gonna take me time
