red oxide?
Do you have to use an etch primer when spraying aluminium? or can u get away with just coats of red oxide then top coat??
mainly because I'm poor and dont want to buy etch primer when already have red oxide :) haha
Etch primer is recommended, however I sprayed a set of Aluminium Motorcycle rims with a filler primer then a gloss black topcoat and they were fine!
supermoto's FTW^^
ill try it! if not get the nitromoors out... again...!
Edited by Lawryy
Yeh, the wheels on my Husky lasted a good 6 months, then I sold it, AFAIK they are still alright!
beautt :p 400 ish? my dad had a xr650 supermoto'd till pikeys nicked it...scared the shit out of me so rapid although tops out bout 110...but its enough....not like there is any fairing etc!
SM610S, 570cc 4 valve single. Had it upto about 100MPH on the clocks, got abit twitchy though, and sounded like it was about to go bang.
I've had 2x ZX7R's also, they were fucking fast bikes, good for over 170mph on the clocks.
You should be ok as long as you do afew coats of the primer and topcoat.
