different bumpers on a 6n?
as above had a lil search and couldnt find anything,
I'm aware the seat ibiza do? :/
i dnt mind work to make them fit, i just want a differnt look from 16v!
  • Replies 12
  • Views 1.2k
6n2?
you have to change the arches too right? what else would need to b changed?or i amagine i could find a thread on here?lol
bonnet arches grill slam panel bumper headlights indys
you need to change the bonnet, bumper, both wings, headlights, indicators, grilles, front panel and cut a section off of the inner wings and weld on the mount to hold the bonnet support
Cheers mate, anyone no of a build thread or anyone previously dne it? I'm guna start looking for parts tomo, dnt mind starting with no idea whatsoever, but I will :) unless isit a more or less straight swap?
Cheers for help
Mate your motor is fucking amazing!!
How long you reckon it would tke working solidly?
It's my daily so really would like to get it road worthy in a weekend if possible?
I'm so doing it after seeing yours tho!!
Again I can't gt over how sick tht looks!!
I'd much rather take time and be proud of tht then spend the money on a 6n2!
its hard to say, i only worked on it at weekends
the main thing is cutting the inner wings mounts and welding in the small plates, then you need to have your headlights and indicators rewired as the 6n2 headlights use 2 bulbs but 6n only uses 1
found this pic i took to show you what its like if you dont cut the inner wings and weld on the small plates
Apreciate the help mate, just to clarify, I cut the small plates of 6n wing and weld to new 6n2 wing?
no its not part of the wing its part of the inner wing (the bits the wings bolts onto, that needs cut then new sections need cut off of a 6n2 and welded in place before the front will slide into place
Ooo i 90% get you, i no I'll realise exactly what you mean whilst doing it!thnks for the advice, if it turns out remotely as good as urs I'll b happy!!
