removing bumpstrip adhesive
alright bin told to use turpz to remove the adhesive from the back of the bumpstrips is this a good idea?
  • Replies 8
  • Views 1.3k
someone help me with this quick I'm going to get it off in a min
cheers
petrol on a rag worked for me.
use a fudge wheel :)
I used a hairdryer.
Fudge wheel ftw!!
I did one side with petrol, this took about an hour and a half. Then for the other side I used a little bit of thinners and it was all off within about 25mins.
Fudge wheel should take you no more than 5-10 min per side. Its specifically designed for that job and you won't end up stinking of petrol/thinners.
wd40 and presser washer
