TT Seats in 9N?
Is it possible to stick in a pair of front seats from a TT?? has anyone done this? I have tried searching the forums but to no avail. Anyway any help would be great!!!
2002 Polo TDI
Thanks guys
  • Replies 8
  • Views 5.2k
it may be possible, audi and volkswagen do have similar parts if not the same in many cases. I dont think no1 can tell u over the net, you are best bet would probably be going to see some1 who knows what theyr doin and askin them, if not you could always buy bucket seats to fit your polo?
yep its been done many a time.
take the sub frames from the old seats and weld them on to the TT seats or get a set of brackets made up.
takes a bit of work thou especially if you want the heated seats and airbags to work.
I'm doing it in my 6n, what i have to do is weld some brakets to the floor of the car so that the TT seats and sit on their runners other wise if you put the TT seats on another set of runners you might find problems with height. Heated seat part.... I need the wiring loom and the switches, you get can most of which either from an audi tt or from newer polo's
i think it is mate i know a guy who got some
you need to get the brackets made up tho they dont just go streight in i think
i fitted a set to my 9n the other day, get a set of subframe adapters fabricated, i.e matches the holes in the floor and the holes that are in the subframes of the seats, if your good with a welder your on to a winner or get someone who's good with a welder to sort it. Only prob i have is the airbag connectors dont mate, but I'm gona put the connectors of the original seats onto the TT seats, this should do the trick!
i might have my hands on mk4 r32 interior, regarding the front heated seats, i dont have heated seats in my current polo, how would i do this?
would i need to wire the loom from a polo with heated seats into the original loom and then change connector block from r32 seats to a polo one?
help lol
yea mate, find a polo at a breakers with heated seats in it and connect the wiring into the loom, then just swap the connectors of the seats. I was in VW the other day and there are apparently oem heated seats for the 9n, but I've never seen any?
dito.
only problem is finding one now :doubt:
