Drivers door stuck
Hi,
My drivers door doesn't want to open in the mornings when it's really cold.
I've checked the seal and it's dry so it's not that.
When i pull the handle it's very loose and pulls very easily, as if the mechanism inside the door isn't catching to open the door.
When the car warms up the handle starts working again like normal.
Does anyone know what the problem may be?
  • Views 1.5k
Could stil lbe the seal, old wives tale is put a bit of vaseline on it. This works, but isn't good for the seal long term. I use a silicon spray and it works spot on. No idea where you get if from as mine goes missing from work, but a furniture polish has about the same stuff in.
second this mine does exatcly the same i take it u have a 6n ?
There are 2 plugs at the end of the door, the top one covers the screw holding on the handle, the lower one allows you to spray the mechanism with WD40, that should help solve the problem.
wd40 on the seal wood work as well
Mine was solid this mornning,
Phoned my uncle, he said try WD40 = no luck
So he came around - Took Window Seals out, then took a heater gun around the edges and it came free, alot of hassle, but id left my phone in it overnight, otherwise i wouldnt of gone to the car untill the weather had cleared
Afternoon! Mine is stuck at home again today because of the same issue. Thought It was just me! I think its the mechanism inside the door, as I've tried virtually everything else! I was there for 20 minutes with hot water, and de-icer and almost resorted to getting the wifes hairdryer out, but was already very late for work!!! Thanks for the info about the plugs on the door 'Dongleboy' I'll try that when I get home, if I can force it open somehow!!! Its still Minus 6 here!!! Should save me taking the door card off... I hope!
Mine does the same. Annoying as hell!
