Problems!
Polo is smashing me up with some annoying little problems! wondered if anyone could help?
first of all i've already seen a post for it, the fact that i cant get into my car if its cold because all the doors seem to freeze shut! the handles go loose and I'm just standing there tugging at it, thats after i've spent about 15minutes trying to get my key into either of the frozen locks!
second, my driver window is on one-touch, it goes down on its own alright, then i press it to come up, it comes half way then goes back down again, then i have to press it about 5 times to get it all the way to the top? i've replaced the switch and tested it with the passenger switch and it still does it?
lastly my rev counter needle seems to have dropped, it starts in the petrol gauge and the red line sounds to be about 3 or 4k revs, the range of movement is right but its just in the wrong place? reckon just a battery reset would do the trick?
any advice would be awesome!
cheers
  • Views 926
Lol i have the same top 2 problems:)
frozen door locks - you can do much about it so you have to learn to live with it, could try WD40 in the locks might help it some people say it does the trick but I've not tried it
have you checked the window motor and the mechanism?
I tryed the wd40 dident work :(
yeah the motor seems to work fine, got it checked by a diagnostics guy who was having a look at it and he said the motor was running fine! it runs fine as in the smoothness of the motion there's no judder or anything it just goes back down on its own lol!
awesome i'll give it a go, temporary is better than nothing to be honest! any idea on the rev counters?
