painting in this weather?
if i was to spray the car in this weather, what would happen?
as in would it dry differently and peel or would it be okay?
cheers
  • Replies 12
  • Views 1.2k
it wouldnt dry and would prob come out blotchy !
What kind of paint you using? If its rattle can i wouldnt, but if your using paint thats duiluted with thinners, use anti bloom thinners. Either way I would wait until there is less moisture in the air.
i did my front wing yesterday in matt black came out pukka but i aint no expert
I've tried a couple of times recently, outside is a definite nono, in the garage you can just about get matt black to dry evenly but its going to need blowing over when it warms up to get it bang on.
Edited by danny6n
in most cases if its cold then the cold air sucks the life out of the lacquer and it will just go dull, best using a heat lamp before painting if you are in a small area this way the panels have a small heat in them to start with then between each coat move the heatlamp constantly along the panel to dry properly, dont get too close though or it will just bubble and you need to start again
hair drier
Or get a heater going in you garage if you can and gt everything really nice and warm then spray it!
so if i was to use works unit then i should be alrite?? aslong as i heat the place up before doing it??
in cold weather paint can go milky, especially if your using cans because of the solvent.
i got a lot of painting to do but am putting it off till we get some better weather and the last thing u want is lots of snow and ice sitting on your nice new paint work
if you can do it in a garage, and get some heaters in there, pluss maybe a few heat lamps/inspection lamps on the panels your about to do then that would be fine! the panel need to be warm for the paint to stick, in cold or even freezing weather the paint is gonna fail! it may be alright for a bit or you could get lucky, but chaces are it will just slide off of smear.
I sprayed some interior parts last week when it was freezing. They came out fine, and I used a rattlecan.
