Polo differences
Hi guys.just a quick question on differences between a gt and a normal mk3.basically i hav a slightly damaged gt,steering arm and possibly wishbone..hav a normal mk3 as a donor but am wondering if the parts are exactly the same.basically wondering which handling parts in the gt are upgraded over standard as i don't want to be downgrading when i replace?cheers,Baz.
  • Views 794
The only handling upgrades on the GT are a strengthened rear beam and use of a bias valve for the rear brakes. All front end parts are the same.
Have a look for those parts from GSF/Eurocarparts or similar, you'll probably find it's hardly worth using second hand bits.
the polo gt g40 has
Roasejointed inner stearing arms g40
Rosejointed inners front wishbones g40
Stearing dampner fitted to the stearing rack gt/g40
antiroalbar welded into rear beam gt/g40
rear brake pressure load thing fited for the rear brakes gt/g40
