G40 Brakes and rear disc conversion
Front G40 Brakes, 239 vented with good Brembo Max discs and Padgid (standard) pads. Were refurbished not too long ago and painted blue, I hated the blue so started stripping the paint off which is unfinished – SOLD
Mk2 golf 16v Rear Brakes with good discs, pads, BNIB scirocco 16v handbrake cables, BNIB VAG splash plates, more or less EVERYTHING needed for conversion hence price, I will break the brakes, cables and splash plates - Please note that the handbrake cables are not a direct fit the MK3 Polo's, iirc no handbrake cable is a direct fit and they all need to be adapted to work. - £130
Located in Leeds - Delivery will be £10 per item due to the weight.
Pictures upon request.
Edited by MrP
  • Views 701
Front G40 Brakes, 239 vented with good Brembo Max discs and Padgid (standard) pads. Were refurbished not too long ago and painted blue, I hated the blue so started stripping the paint off which is unfinished – £60
if your going to the rr day il take the front brake set up..
Sorry dude, Not going. I can post for £10 tho.
Rich.
hi intrested in the front g40 calipers, carriers,disks and pads, were are you based,
thanx luke..:)
Items are in Leeds, Postage is £10 for anywhere in the UK.
Rich.
