How many miles can you get out of a full tank?
I was ponderin on this issue, as according to most people, my gti should average out on 33mpg, and there is roughly ~10 gallons in 45litres. So I should be getting 330miles out of a full tank. Now I remember last week I filled up, and did 30 miles each day (from Chessington to London is 15 miles each way) for about 6 days a week, and that finished my tank. That entire trip was only 180miles though, so what gives? :-(
  • Replies 14
  • Views 17.4k
Depends what kind of driving you're doing, you'll see a lot more miles out of a tank if you're on the motorway.
If you're going through congested places, a lot of stopping and starting and you'll see a drastic increase in fuel consumption.
The cold weather affects the engine efficient engine having to work harder and warm up. also check you tyres are inflated correctly, tyres drag increases fuel consumption.
And also depends what fuel you using normal or premium and if you have put injector cleaner through recently or on a regular basis
Or you could have a fault my car was massive over fueling with a damage lambda probe causing the ECU to think that the engine wasn't getting enough fuel.
Since I got it, it uses V-Power, and only that. Wynns injector cleaner once a month as well. However, my driving involves alot of stopping and started, as anyone who lives in London will tell you, so maybe its that then.
Try and travel with as little stuff in your car too, extra weight will mean you consume more fuel too. My car is always empty unless I am taking something with me somewhere. Remember the MPG figures they come up with are for an unladen car.
I can get over 500 miles to a tank :)
I average 300-320 miles to a tank.It can involve motorway driving or town driving.Try not to stop as much like slow down earlier when approaching red traffic lights,that way when ypu arrive they are 8 times out of 10 green.Same with roundabouts judge you speed better and you'll stop alot less.
Thats if bothers you that much haha.
probably dont get the economy because you have to turn the car on and drive on a cold engine at least 12 times if you are going to and from work 6 days a week
if you did the same journies one after the other without switching off your engine i bet you'd have used a fair bit less fuel
My dad managed to do 406 miles from a full tank in my 6n 1.4 polo. Pretty pleased with that. :D
40miles to £5 out my mk3 1L
All of these discussions of how many miles one guy got to however much he put in is pretty inaccurate anyway.
Other point is you need a reliable way of checking your economy, not "I put 5 pounds in, went so far and then put another fiver in"
1. Fill your tank.
2. Reset trip counter.
3. Do a good distance, like use most of a tank.
4. Fill up
From the receipt from the second fill, you'll have how much fuel you used in litres. Divide this by 4.55 for gallons.
Divide the number of miles you did by the amount of fuel used in gallons, this gives you your average econmy over the distance in mpg.... far more understandable than fivers.
my 6n 1,4 8V usually gets about 400 miles per tank, allthough i usually fill it up before it gets too low
virtually all my driving is on the motorway so yeah... when i go back home and end up driving round town lots its drops to 300 or less
I average 267 miles to a full tank in my afh bike carbed saloon
Not bad I dont think seeing as though my gt only did a little more
1. Fill your tank.
4. Fill up
I'm going to try this, cheers!
