Steering weel assistance!
just bought a new steering weel for my mk4, its the same one but brand new (with airbag)
would anyone be kind enough to post a little how to swap it guide lol
i have a rough idea and assume its quite simple but any help would be much appreciated!
:-D
  • Views 723
here's a brief one literally going by the Haynes manual..
First - disconnect battery (-ve). This is because you will be fucking about with airbag wiring and you don't want it going off.
Undo two allen bolts at the back of the steering wheel to open up the front, containing airbag.
Disconnect yellow connector mounted onto the airbag itself, and pull out airbag (carefully).
Disconnect the other airbag connector behind the actual steering wheel.. it's on the wire(s) wrapped in foam, underneath the column.
Undo the big fuck off steering wheel nut (22mm IIRC)
Pull off steering wheel
Replace as above but reversed..
Make a mental note as to the orientation of the wheel as it came off
Probably best to centre the wheels before you start tbh
Oh and may as well give the horn contact ring a good wipe / copper grease whilst everything is off
Anything I might have missed I'm sure will be added by others
:thumbsup:
Edited by CWA
:thumbsup:
You sir, are a legend :thumbsup:
