Pictures of 175/50 tires on 8x15" rim
Does someone have pictures on how 175/50 tires looks on 8x15" rims? :)
Edited by Ronhap
  • Replies 26
  • Views 5.9k
could you really not be arsed looking for this? Plain Lazy.
clicky linky
I have seen the pictures on tyrestretch, but how does it looks on car (VW Polo)??
Here is also an picture I found..175.50.13 on 8" & 195.45.13 on 8.5"
Edited by Ronhap
heres a 195/45 on an 8j on mine, it looks very similar depending on tyre brand and offset. Offset is pretty (actually, very) important when seeing if stretch will get you under the arch, just because one wheel fits a car with stretch, another with a lower offset might not.
for the record, they didn't fit comfortably without arch work.
I'd go for 185/45 on an 8x15 personally
x2 on that one!
I need 165/50 to stop the scrubbage, like I say, depends on the offset, its trial and error though really.
bridgestone and nankang give the best looking strech imo..
i have 175/50 bridgestone potenza's on my 13's and looks spot on imo..
I'll try and get some pics up but I always ahve trouble, but I'm running 175/50/14's on 8j rims on my daily. Touch wood no problems but they are pretty damn strecthed!! Don't think I'd want any more on a daily!
Nankang have that stupid rim protector, they look gash! Federals and Proxes for me... Agree on the Bridgestones though.
Proxes have rim protection too.
195/45 proxes stretch awfully IMO on an 8j.
i swapped mine after one day to 185/45!
the 165/50 is a rather big stretch
If only they did 185/45 n 14's :(
I have 195/45 T1R's but haven't had anything else to compare them too.
i also found toyos to wear quite quickly on my solitudes
Yeah but it's not as big and noticeable as the nankang one. Couldn't quite find a like for like comparison between the two but this isn't far off, the sizes are different but the wheel with the proxes is 1.5" wider and the tyre is just over an inch wider. But look at the stupid shape it makes the tyre take, the proxes dont look half as bad. I've seen them both in the flesh and proxes defo look less daft.
Edited by danny6n
165/50s in nankangs stretch terribly
Just while we're on the issue of stretching tyres, I've been on 'TyreStretch' and I can't find a 195/55 on a 8" wide rim. Is a 55 sidewall too big or something?
Yes it is.
It would look appauling, because the wall would be too tall.
So it would look appauling, but could in theory be done?
Oh yes it can definately be done no question, but there's no reason why you would ever want it done.
Because of the "huge" tyre wall, it won't look that stretched.
The reason I made this topic is because I want another tire dimension on my Schimdt ML 8x15's, today I have 195/45.
And I cant get it as low as I want with this dimension, so I consider 185/45 or 175/50.
I like strectch...but I dont want to have TO much stretch.
It's hard to decide! :?
Edited by Ronhap
I'd go with 185/45, what are the offsets on the wheels?
Sorry to hijack Ronhap!
So in effect, it would look normal but actually be stretched?
I may need it doing as the wheels I'm getting need to be run with a 55 profile otherwise I'll have a big arch gap. I've got 195/55s on my current wheels, and plan to swap them onto this new set. Desperate measures, in other words.
Edited by PSWPolo
185/45 all day long!
i will get you a picture of mine off the car for relevance!
