help please guys
Hi guys erm just wanted to know how do you take the rear VW badge off of a 6n without breaking it does it simply flick off of is there another technique????
I've used the search function but couldnt find anything,
any help appreciated (:
cheers Lewis
  • Views 778
Not sure on a 6n but on most dubs I`ve had there were two prongs that held it on, these go through the bootlid. Pop the cover off the rear wiper area and have a feel about to find out, if you find them just give them a push and the badge should come off. To remove the cover from the wiper area you have to pull it off from the TOP edge.
on a 6n its just glued on, just take care when taking off you dont brake it, to stick mine back on i just used the double sided tape you you to stick show plates on and stuff, get it from halfords for a few quid, works a treat.
exellent (: thanks guys (Y) its now in the process of bein sprayed candy white (:
nice is did the VW bit white and the background illuminous green. also sprayed the reg light's surrounds illuminous green aswell.222
