MK2 WINGS!
I've took al the bolts-screws off that i can see need takin of but stil the wing aint mooving :| any help guys? will be very helpful
its a 1990 mk2 breadvan.. :)
  • Replies 11
  • Views 1.9k
there stuck along the back edge with sealer...have you taken the bolts out of the back edge on the A pillar? they will be hidden by sealant on a untouched car
urm are these bolts like on the edhe were the wing meets the door?? I've got evry bolt out that i can see :?
put your head where the wheel is and look to the back of the car, where the wing returns 90 degrees into the a pillar there will be 2/3 bolts from the wheelarch side into the front of the post, think there 10mm but as said above if there og wings will be covered in silicone so you gotta pick about for them
cheers dude so al need to take the plastic trimming of from under the arch thenn ?? :|.
yep
Where its white top and bottom two bolts
Edited by Daryl
yep
ahh cheers bud so the plastic under the wheel arch will need to come of to get to the bolts?? (jus to be sure).
Yeah take the plastic mud tray thing off. Undo the bolts on top in engine bay then two screws at the front. Next one is at the bottom of the wing then when you get the plastic out you have two more bolts that will be covered in sealant to get out.
Then the wing will come off
Edited by Daryl
alright matey cheers for coverin that many thankss :).
deon.
Deon let me know how you get on with this cos I might need to do it myself for some rust. Not had chance to get close and have a look with the snow.
What you taking them off for anyhow?
urm pretty much the same thing ther rottin so betta change them sooner then later :) lol and yeah al let you no matey i got al the bolts of that were visible quite easy jus the hard to reach 1 next :).
I've seen a few mk2s on here where they have taken the wings off and its really rusty same as some mk3s I've looked at. I was lucky when i took my wings of to check it only had a small amount of suface rust.
