Audi tt pedals
Alright peeps, anyone know if tt pedals fit straight on a ml4 polo? Think they look sick and want some on mine. :). No nodding involved and screw straight on? Anyone let me know please, pictures with them on polo's would be much appreciated. Cheers, tom.
  • Replies 8
  • Views 1.6k
Search?
i have them on mine! (and i have a spare set for sale ;) ;) ) the brake and clutch fit strait on. to get the last one to fit i got a grinder and just took a tiny bit of the edge of the pedal, could do it with a file or somthing. Easy as! and i whacked a bit of glue just to finish the job! :)
hope that helps
I own a mk5 6n2 gti so the pedals may be different to the mark 4 but probably the same. I've just fitted my TT pedals £29 for all three from VW. The brake and clutch pedals fit straight on. Literaly just have to take off original rubber pedal covers and put new ones on. The accelerator pedal is a little harder. I removed the plastic pedal cover off the accelerator (with force) then stuck this with super glue inside the new tt pedal and then cliped it back into place. It is very difficult to fit without removing the original plastic cover. Hope this helps :) And yes they do look 'sick'
i had them on mine.. i didnt have to shave anything off my accelerator one .. i very slightly bent it so it arched a bit more and it went straight on
Am i right in saying that The accelerator pedal from a Left Hand Drive Is the one thats needed?
the link i posted says that
you are correct.
Either Left or righthand will fit.They both have to be glued on and if you look at the pair of them the're identical.I bought a set off German ebay for £15 so may be worth alittle look over there.
