Boot lid respray (mk3)
Hi guys,
This is quite a noob body work question as I am one lol. Its not my strongest point but I am persistant to get the hang of it and the patience so I'm going to give my old boot lid a respray, rather than give it to a garage to rob me of 100quid ha.
I currently have a badly smoothed boot lid on it that was already done and have my old boot lid that is a standard one. It has a few areas that are quite badly rusted so what I've done is I've gone at it with a wire brush disc on a grinder to take the paint all the way back to metal to start again. As I've seen jobs where sanding has occured and has left dimples in the surface and looks crap. Anyway, once I've finished stripping it off, I assume the surface will not be 100% even. What steps should I take to primer the metal? what type of primer? should I keep applying layers and sanding with a fine paper until it is smooth?? Just general info will do I'm not after a full write up, I'm sure everyone has better things to do with their day.
Any advice is appreciated. Thanks.
Ow and I can post a pic if required of the boot lid as it is, it looks pretty cool chrome lol.
you'll need to go over the bare metal areas and the small area around it with 80grit pad so it gets a good even bit into it, then go over it with 240grit, if its just bare metal and no paint give it a quick red scotch all over and make sure to do the edges, give it a coat of etch primer, then 3-4 heavy coats of high build primer, leave to dry in a warm area, dry or wet sand whatever you repair, i always we sand, takes longer but the finish is better, use a block to wet sand it (i use the 3M sanding block) so the primer is evenly flattened to give a flatter finish when its painted and lacquered
Great for that. appreciated. Ill give it a go.
