Real Help Needed To Cure Damaged 6N2 Polo Project
Hi, I have a 6N2 polo 2000, x-damaged.
I had my dad do a decent job on fixing the rear dent. The car had been impacted from behind... I have had a new tailgate and bumper replaced and gthey will need spraying but before that I have a couple of problems.
When the car was hit I believe that on impact the force pressured the rear quarter panel/ arch but on one side only, to push out. Now I haven't took it to a bodyshop yet, but I would like to know how this issue will be fixed? The rear end looks mint basically because the rear bumper covers the damaged area.
But my dad said he had trouble with the boot closing and he had to use a jack and some pieces of wood in the rear boot to actually force out the shape back to it's original position, obviously this isn't looking like a factory finish but The rear boot catch seems to be slightly out positioned. And in the dash the boot lid open light is always on.
Any help would be much appreciated.
I will load up some pics and maybe somebody could take the same pics and we could compare them to see where the issue is with the rear body and rear quarter panel.
Thanks Buds
  • Views 902
Thanks Buds
I'm a self employed panel beater sprayer. basically your car needs more work than just replacing bolt on panels. the only way to fix this would be to pay a bodyshop to professionally pull the rear of the car back to its original position, this will relieve the tension on the rear quarter and make it repairable. to be honest its someting you should really claim off your insurance to fix as it will be expensive. you also run the risk of exceeding the cars repairable value and have the car written off
