polo handling mk2 v mk3
Are there any differences in the chassis between the two? Does one handle better than the other?
  • Replies 38
  • Views 3.4k
Both the same iirc, but I've never driven a mk2...
I'm of the opinion that the front ends better cross-braced on a mk2.
yeah in standard form the front end of a mk2 is more solid, plus it's weighs a bit less which always helps.
If i was to want to use a polo base as a track car, then a mk2 would be best?
It's what I'd use, so long as it's not getting rust.
Interesttingly, breadies are lighter than coupe's,
Mk2 is less floppy than a Mk3, but still plenty of scope for improving things. Brace up a Mk2 and Mk3 the same and you'll not see a difference.
Yep. So are loons. :(
loons are lighter than coupes... that sounds wierd ay?
Very strange as a saloon's basically a coupe wit a bit welded on.
I'm sure saloons are heavier than Coupes - they've got a bulkhead between the rear shock towers, a longer boot floor and rear wings. I remember years ago Paul Borthwick (first UK Mk3 G40 saloon) saying they're about 20kg heavier than a coupe..
Mk3 coupes are heavier than breadvans because of the heavier tailgate. But a breadvan is basically the same size as a coupe.
I'd say a load of extra metal out back on a saloon would more than balance that difference.
Cue MikeyMK with the scales to prove me wrong... :lol:
Edited by Alex
subframe with full wishbone conversion will make a huge difference on both.
excuse my lack of knowledge ^ what do you mean a full wishbone conversion?
polo performance parts sell them. 'subframe kit stage 3'
mk3 look like a more stable car imo.
mk2s look like the wheels will buckle when going round corners :lol:
Forget the science then, it's down to looks. The reason a mk3 looks more solid is because it has square headlights and a big bumper (that doesn't actually fit that well). So therefore a 1986 fiat panda's more solid than a new mini?
Ahhh dont be such a cock. We knew what he meant.
Mk2's do look quite unstable cos they look so high and light lol. Almost like they might blow over. :-D
correct.
If you read what i said.... LOOK
Doesnt mean it true now does it? :retard:
wouldnt say he was been a cock :S
looking at the polo cup, it seems the mk5s like rolling over far more than any mk1/2/3 i've seen.
i think in standard setup, both mk2/3s look comical because the fronts are so so high, but they do handle surprisingly well in standard guise if you have some decent rubber.
the mk2 feels more exciting to drive, and i prefer the squarer looks rather than the curved look of the mk3.
as said above the subframes with wishbones make a hell of alot of difference, when i fitted on to a mk2 (along with some other choice suspension goodies), it ran rings around my mk1 golf gti!
Sorry if came across that way, was typing whilst tired and trying to multitask in a way being male I wasn't born to.
I want to build a g40 turbo track car, so i think ill use a mk2 as a base then. Just wanted the best starting point
I was under the impression that mk3 coupes are slightly longer than mk2s...? Maybe something to do with the "smoother" look?
Correct - they're a bit longer up front to make room for the charger on a G40.
Saves making two slam panels (like on a Mk2 - one of which has a removable cutout section) if the G40 is a proper part of the range. Mk1s are even shorter, the charger pokes out of the grille!
Yeh I thought so.
After seeing randombadger69's mk3 g40 next to his mk2 coupe, the mk3 is definately longer at the front.
