Most annoying thing about my polo...
I have this MAJOR annoying squeeking sound coming from my bloody air vents in the middle above the radio... no matter how many times i wack bash flick it kick tiggle it kiss it speeak sweetly to it the bastard thing never stops... jsut going along and squeeking like mad its like driving a van, to top it off i got a rattlely exhaust.
So what sounds does your car make! ??
  • Replies 22
  • Views 2.4k
my elictrics in my car obviously have a fault and when i speed up there is a whining noise very much like a supercharger. ao really its a good sound 8-)
see i dont have that probelm as i dont have middle vents!
The most annoying thing used to be a rattle behind my dashboard could never find it took many things off, seems to have stopped now :)
lol whinning noise... that dont sound good, i had that and POOF went my gearbox, £250 later and nearlly a year on and still very strong!
Dont even get me FUCKING started!
I have so many rattles and i keep fixing one and another comes along, squeaks rattles bangs bumps. my bloody drivers window is kinda fluttering atm! drives me insane right in my ear!
How can i fix that? i have no idea!
I have to open the window for wind noise or put the radio up lol
rattles drive me MAD!
its called Character Matt :D
I used to have little rattles etc. like my centre consel rubbing against by dash but cant here anything now...
No i haven't gone deaf lol. Just got a full stainless system for my valver so all i here is braaaaaaaaaaaaa. all the time lol :)
Kuszpit :)
I've got a 6n decked on coilys with valver alloys the same as you and my exhaust rattles like fooook, jacked the car up and it appears the exhaust is hitting the lower subframe so fuck knows how I'm gunna get around it :lol:
My centre console doesnt squeek tho :?:lol:
Sam
Count yourself lucky, some of us have vents that dont blow hot air
Sam
Lol my valver done that too :) just replaced it an dit does the same thing. :S have new rubbers on the way as this is why it is doing it on mine anyway :)
hahaha remember this in most of my brothers Golf mk2 gti's or his mk1's etc :D
I have the same problem, bt it doesn't all the time, comes and goes when it feels like it... Proper annoying high pitched squeak
Edited by D16RRT
It's probably the bearings on the blower fan. It will normally start/stop when you change the fan speed. You could try a bit of WD40 on the fan but its quite hard to get rid of once they start doing it.
You no nothing about squeeks untill you own a mk3. there spanish built which is another word for lazy so when you go over any kind of bump and your down on Phill J shocks and springs you actually see the interior dancing about.
Quite funny tbh.
My valver has a couple annoying rattles too, exhaust hits off the underside of the car and I have tried everything to sort it but nothing works.
My fan on setting number 1 chirps away like a little bird behine the dash.
If I have my window down at all it rattles in the door and occasionally the sunroof cover thing decides to rattle.
But hey its just character at the end of the day.
My BMW has the best one though, its all good and calm inside the cabin until I get up in the high revs just about on the red line when something around the gearstick area starts to vibrate and rattle, decided its just the cars way of telling me to change up, like a primative shift light haha.
Mine rattles like crazy, passenger door (sounds like the winding mechanism rattling behind the door card) drivers side door pin, no matter how often i tighten it up it always come undone, both tweeter covers in the dash have broken clips so just rattle like mad, glove box door rattles, boot lid rattles but i probably just need to adjust the little rubber things, off side drive shaft rattles against the chassis, and the exhaust rattles just near the downpipe.
Still love it though and when its a bit warmer i can probably sort 90% of them, but at the moment i'm just happy to get to and from work everyday without stacking it in the snow!
I only have one rattle in the rh door and I can't figure out what it is. I've taken it apart and it still sometimes rattles. Then there's the shoddy pieces of plastic VW put on top of the door cards that squeek if you press on them. Then there's the whistling coming from the back. Then there's the nearside rear wheel thumping about because I knocked it. Then there's the clutch pedal squeek(maybe it's just telling me it's on it's way out, or it's the pedal box going, fug yeah). And then the seats rattle if you shake them. I sorted out the exhuast though, fug yeah.
Ok fine, more than one.
See my squeeking happens even when my fans aint on I'm actually starting to think its the center console which is just squeeking.
Oh shit, forgot about the squeaking fan. Eugh. Luckly it's not really loud.
my mate has this on his old clio.
he has a sub etc, usually it goes with your revs and all that.
think its a bad earth if you have a sub etc.
if not still probs a bad earth imo
those of you who have an open air will know the interior light is embedded into a big square piece of plastic which covers the open air motor
the whole thing has the tendancy to fall off whenever i hit a pothole or bump and whack me in the head
it then swings there from the interior light wires just laughing at me...bitch
lol :-D, love that!
Lies... It does it time after change in fan speed, change in acceleration spped, turning of corners :lol:
:lol: Thats jokes,i chuckled hard..
My one issue isn't so much an issue for me,but it certainly is for my passengers - they never shut the door properly first time,so have to re-open it and near slam it.
I get moaned at a bit for this apparent inconvenince,but my excuse is that its an old car and they're used to modern cars with their massive 250kg sprung doors.. so they're just not putting enough effort in!
I've adjusted the door so it sits perfectly flush,and the panel gap is perfect,but it just takes an assertive/firm hand - its character for sure,but is it normal of the pre-'94?
(G40Supercharged @ Wednesday 13th January 2010 - 12:17pm)
(D16RRT @ Wednesday 13th January 2010 - 10:20am)
My old one used to squeak,but only on flats or stationary. Leads me to believe the axle spindle/cylinder of the fan drum 'polishes' smooth in use and creates the necessary surface for squeaking.
Theoretically then,if you sandpaper the spindle a little to roughen it up,the squeaking should stop.
I would only care if it was in the G, it's not so fuck it, my moto :lol:
