6N2 Central Locking Pump Wires
Hi can someone tell me what coloured wires do what on the central locking pump Thanks!!
  • Views 1.4k
white/green is the lock wire
white/yellow is the unlock
both can be found in the drivers side a pillar and the drivers side sill
what about:
2 x pink/white
2 x brown
why is there 2 yellow/white and 2 white/green
i accidently cut the red wire but my locking still worked... so I'm guessing its not a live power wire... !? confused
the 2 brown wires are earths
no idea why you have 2 of each of the yellow/white and the white/green
you could really do with testing the wiring with a test meter
i don't understand why you are having so many problems
