Small Spline
How do I know if I have a small spline steering column? I've searched and some say Mk1 and early Mk2 had the small spline and late Mk2's and Mk3 had the large. Others say Mk1/2 Small and Mk3 Big.
Is there any way of telling by measuring ?
Change over happened in 1988, so if yours is a 1990 or 89 mk2 then it is likely to be large spline.
looking at your pics I'm saying u have a large spline
Easy enough to just whip the steering wheel off and quickly have a look. As far as I'm aware the large spline is just a sleave adapter, or at least it has been on all the low spec cars that i have converted to g40 spec.
You can still buy the adapter sleave from VW, last one cost me under a tenner if i remember.
Matt
Cheers Guys.. Well mine was built in Nov 89 so it will be large...
Humm I got it into my head that the column is thicker (larger) but its just the teeth that are different then?
Edited by max_crox
