Polo 6N2 Fitting a Outside Temperature Sensor..
Guys,
I'm thinking about fitting an outside temperature guage to my 6N2, i thought about getting the GTi clocks, taking out the little center clock and changing that for an aftermarket temperature guage, and just using a exterior temp sensor off another car and fitting it, might be a fairly decent mod.
Few questions..
1. can i change the milage clock in the GTi 1s so that i can put my current 1 in (LED display)
2. are the chrome rings 1 whole piece with the black surrounding or can i modify it all to make a cross breed
Any ideas would be great..
(Or I'm thinking of finding a rear view mirror with inbuilt temperature guage and auto dim and just fitting that)
Dimz
  • Views 3.9k
isn't the temp sensor in the wing mirror? as for mileage i imagine it's the same as mk4 golf etc you can 'correct' the mileage on a unit once then it's locked. as for the rings i never managed to part them, just get gti clocks and surround for clock.
Olly
news to me about the mirror thing! can you elaborate or you not sure?
i might just use a an aftermarket pod and fit it in the same place as the clocks just wanted to keep an OEM look to the dash..
Dimz
i'm 90% sure, there's a little bobble on the bottom of one of the mirrors and that's the temp sensor, hope i'm not confusing it with the ibiza cupra.
Olly
i think its only in the AC model's that it has that, hmm I'm thinking of just finding myself an audi rear view mirror with temp and compass and fitting that and put the temp sensor in the side mirror anyway lol..
Dimz
If you would like to get semi technical, the outside air temp sensor is literally a purple/white (I think, it's been a fair while since I had one of these apart) wire which goes from the sensor to a pin in the clocks.
It wouldn't be impossible to actually fit some polo GTI clocks and just get this feature working but it does seem like a lot of effort just to know how cold it is outside.
simply get a bird, put her in the passenger seat and when you're curious if it's :
warm
freezing
not bad
wind the window down, let her freeze or be warm a little bit and then measure the temp using the nippleometer.
warm
freezing
not bad
lmao :lol:
