"PJ" 6n2 valver
Hi guys just wanted to post some pics of my new car.
I want to lower I'm get the rims out a little without getting out of the body... or else i get a hefty ticked, and i want to swap the grill for the gti with the red lip.
NEXT: Boot build project underway guys! Don't kill me for putting 6x9 on the boot... they where from my 106 and its either that or its tweeters only as my door speaker went bouuummmmb.... today is just the mock-up on card box tomorrow il probably have it done.
Don't look at the speakers they where there just to make sure it would fit.. the position will be slightly different.
Suggestions open;)
cya latter.
Edited by J.T.Melo
  • Replies 24
  • Views 4.5k
Boot build underway check up!
Looks good tbf - why not just stick them in the shelf?
I don't stick them in the shelf cause, i had them in the self in my 106... pain in the ass... they get shaky and if someday i want to take them out I'm left it a parcel cut out xD and they stand out...
Edited by J.T.Melo
oh dear
^^ oh dear what???, looks nice for a good start there mate, get some more boot build pics up mate
Good project base.
Let's see what you'll gonna do in that boot ;)
do you already know the portuguese polo fan site?
check out my project,in these forum,and you have there the site ;)
I'm also a member of that forum...
boot build out of cardboard? Is that to save weight?
do you think that he'll go do it with cardboard?
what is to see how it will look...
he will just be making the template out of cardboard ( i hope)
loool I'm making the template outha cardboard xD il put the boot build pics tomorow. for now its simple. i plan to had more stuff like an amp and better speakers.
Nice one it the weight saving xD, but in fact if i wanted to save weight i would get the rear seats out and not put things on the boot xD
here's a quick mock-up in wood.
sry for the crappy pic but its the best i had at the moment;)
cya tomorow guys.
Edited by J.T.Melo
nobody understands sarcasm.
sry no boot pics iet... just a quick question... i want to lower a little bit like 40mm my polo... whats the best kit?
1- Springs only
2- Springs and coilovers
3- Value
4- Value Quality
5- Quality
I know this isn't the place to make this question but since this is going to be a progress tread...
Thx in advance
coilovers all the way ... 40mm is nothing really m8,
atleast with coilies you have the choice of height.
  • 4 months later...
Hi everyone, sry bout the absence here, having a lot of work both pro and school wise.
Have some little updates since last visit. First the boot build, the first project went out the window since it was very unstable.
Here are the pics of the current build, and don't kill me for the 6x9 their good for what I need them xD
Next i decided to cover the speedo visor with some fabric.
Next step, out goes the headlights for some annymod.
Headlights on with gti grille
Next, the air intake valve that switches between cold air and hot air went bust and only provided hot air... solution?
Wheel cover off
First tube off
All tubes off
BIG TUBE IN
That's all for today guys, ill post some more when I get the car cleaned ;)
Comments ;)
Edited by J.T.Melo
Just got off the free-way, got to 120 with no hassle =D (I'm assuming I made the right conversion 120mph /= 200 kph) in fact it was a 210 but the gps scored 200 kph.
Without the latest air mod, it would get there but it needed more road and more throttle.
If only I could afford the coil's... need more tim€.
suggestion are welcome guys 8-)
Its looking good mate, maybe you could look to trim more of the interior with the suede? Is the hood over the dials easy to remove?
the headlights and the fabric clock surround are nice touches
6x9's inside the boot confuse me a little as theres no way for the high's and mid's to travel into the cabin properly. but the workmanship looks spot on
maybe change your standard air filter for a k&n or pipercross panel filter, should add a bit of grunt and let the air flow more freely and cleaner
the hood over the dials is simple to remove if you have removed it once, in the first pic of the hood you see a little screw, it's a torx, don't know the size now, you remove that, then you try to take only the first part off, i had to take the hole thing like you see on the second pic and snapped some plastic bits... But either way it's a matter of getting the torx screw off and then handle it til you get it out.
I plan to trim the door card with perforated leather, change the gear gaitor, custom made, and ad a badge to the steering wheel.
The 6x9 on the boot are just for filling not definition wise, but it was either that or no speakers. This way I have some sound depth. Bout the air filter I'm planning to get a K&N box filter and work the box for more air input. Next up, will be replacing the air pipe with inox pipe, since a m8 spotted my bay and said he had some inox tubing laying around the shop :D
The air filter must be a wise choice cause I don't wanna get pulled over by cops... Here in Portugal, if your car makes a little noise and it isn't a BMW an Audi or a Merc you get pulled over and "asked" to pop the bonnet... it's bout 300€ fine... plus a extra inspection to get it legal...
that playstation looks cool as fuck haha!
does the playstation link to anything
it links to the radio and to a seven inch screen i keep in the car, I don't want fixed on the dash, that way i take it off and put it on when i want it.
Il post some pics of the system online.
Cheers ;)
Nice use of clothes pegs :lol:
I told them: U HAVE TO STICK TO THE PLASTIC!!! GRAB IT!!! xD
i like this idea, i have a raise fake floor and think its just to flat, so this might give it a bit of height :
hope you dont mind mte I'm using your idea :ninja:
