Replacing Openair roof mk4 Polo
Hi,
I have a 3door mk4 Openair Polo and the roof is starting to go into holes it doesn't seem to be leaking yet but I don't think it'll be long before it starts.... so.... the need has arisen therefore to replace the roof. It's an old car so I don't want to spend heaps on it, i.e. no more than £200 or so & preferably less as I'll probably need someone to carry out the work to fit it at additional cost.
I know the whole thing can be removed and replaced but can just the fabric be replaced? It seems such a waste to throw away something that still works. If yes how can it be done? Where can you buy just the fabric from? Who does this kind of work?
If the whole roof has to be replaced where can you buy them from? Do you have to get second hand one or are they still made new?
All info/ideas welcome, please, PLEASE help!
  • Views 1.7k
i have exactly the same problem!
http://www.carhood.com/volkswagen.htm
this is the only thing i've found, don't know what it includes
but it seams steep just for the vinyl!
let me know if you find anything different please :-D
Yes, I found carhood on my internet searches but from what I can gather it is just the outer covering and the price is before you even think about getting someone to fit it, eeek!
uh oh, bad times!
i took the roof off mine yesterday cos the rubbers we letting water in,
it was an easy job to take off, i can imagine the interior roof lining is the hardest part to put back!
i don't have any interior lining in mine tho! :-D
i'll probably end up trying to find one from a breakers and just take the whole sytem and motor,
but at the moment i'm gonna stick with the duck tape haha!
hi i changed over my roof last year, it was cheaper to buy a whole new roof than to get someone to repair it , i found one on ebay for £120 brand new condtion but had been on another polo. you just need to look out for them as they are hard to find, it is a fairly easy job to do it's alot easyier if you remove the sunvisers and the whole head lining via the boot, then it is about 20 torx screws holding it into place, once they are removed you can pop it out but there is also a metal frame that needs to be slighed out, cut the wires and remove it. clean around the edge where the roof was and fit new one, solder the two wires so it works and its all done. obviously you have to refit the headling but the most diffacult part is puting the rim back on and needs two people for a easy job. you can get brand new roof's if you want from the company that makes the original but i cant remember their name it was on here a while ago. :)
found it the company was called webasto
here is there website http://www.webasto.co.uk/home/en/homepage.html
Edited by rustproof 16v
