SOLD
For Sale:
AFH Crankshaft - SOLD (ideal for ligthening)
AFH Con Rods - SOLD
AFH Flywheel - SOLD
AFH Inlet Manifold - SOLD
AFH Pistons x3 SOLD
AFH Airbox - SOLD
AFH Rocker Cover - Sold
More parts and pictures to come so check back
All parts removed from 82,000 mile engine
Edited by matt-polo-6n
  • Replies 41
  • Views 2k
Hey mate, I ll take the Flywheel, Inlet Manifold, and the good pistons. Can you calculate shipping to Athens Greece :).
Thanks for your time Kostas.
hi mate, long time no speak lol how you doing?
yeah will get a price on shipping those out to you
I am fine mate although work is killing me... Have you killed the polo mate? Seems like you opened a little hole in the third piston :-( .
yeah a hole opened up on the 3rd piston, I'm not entirely sure how it happened, first suspisions were a dropped valve or two but took the head off and all is ok so abit confused now :?
only other damage than the 3rd piston is that it melted a spark plug, and there's some slight scoring on the 3rd cylinder bore
the polo is back on the road now though with a new AFH lump in it :)
have you still got the main bearing caps with the block? have you got a picture of the score marks??
is it the block that takes the chain driven oil pump or the later duocentric pump?
SkodaBoy:
yes i still have the main bearing caps with the block, i will get you pics of the score marks, whats your number or email?
it is the block that takes the chain driven oil pump, also have the oil pump and chain if you also need that?
Capamaru:
postage will be around £55-£60 for those parts mate
For Sale:
AFH Crankshaft £30 +p&p
AFH Con Rods £25 + p&p
AFH Flywheel £20 + p&p
AFH Inlet Manifold £20 + p&p
AFH Pistons x3 (numbers 1, 2 & 4, number 3 has hole through middle :( (No longer come with piston rings) £15 + p&p
AFH Bottom End (Bare, internals removed, ideal for re-bore if you want a bigger cc bottom end, cylinder 3 bore has slight scoring) £20 + p&p (may be cheaper to collect)
AFH Airbox (has been drilled to give deeper sound) £10 + p&p
hi mate do u have the throttle body???
For Sale:
I don't sorry, needed to keep it for my new engine
cheap working afh head needed, dont need inlet/exhaust/dizzy.
would like thermos housing is avail
drop me a pm.
could do with a spare afh sump too, or a lupo/polo gti one if avail
drop me a pm.
i have the head mate, 2 of the valves are ever so slighty tweeked though, was planning on keeping it and having some work done on it in a couple of months, make me an offer though and ill have a think,
only thermos housing i have is on the car and could do replacing itself lol
i have a spare AFH sump but was planning on keeping it as a spare just incase i need it, make me an offer though, may change my mind :)
Pm'd you buddy, do you have a throttle body by any chance??
I don't suppose you have the entire timing setup including water pump and idlers etc?
I'm also after a distributer
Cheers, Mark
i dont I'm afraid,
think i may have a distributer though, ill have a look for you
gearbox? If so whats it condition.
no gearbox sorry
BUMP
i have loads of little bits that arent listed so best to send a pm if you need anything and ill see what I've got :)
throttle cable?
throttle cable?
I've searched but i dont have a throttle cable sorry.
BUMP
Mate inlet manifold still avaliable?
Dimz
Dimz
It is indeed mate
any luck with the pics of the airbox?
Sorry mate airbox sold now
matt starter motor and top timing belt cover?
pm me
have you still got the flywheel?????
