How do you checker your interior mirror ?
Would like to know how people do there interior mirror checkered and how to do it as i would to do this to my mirror :D
  • Replies 10
  • Views 1.4k
Pull it hard and it should come off then just sticker away afaik
sounds pretty simple to do man ! anyone got an pictures of there checkered mirror so i can see what it looks like ?
Dont just pull hard you will break it!
On a 6n, hold the shaft that attaches it to the windscreen and twist it anticlockwise - this will release the whole lot from the windscreen :thumbsup:
this is mine [best pic i have of it]
mine i just printed out the check and the cut it to fit and used double sided mounting foam to stick it on its not perfect but looks fine it think =D
Not hard.
Remove the mirror by twisting it off.
Then spray it all white. Then mask it off in squares, then respray it black. Peel off the tape to reveal checkers.
cheers guys ! will attempt to do this to mine on wed :D
i bought a sheet of white sticky vinyl from ebay for like £1.50 .. and just cut squares out and stuck em on.
Chris
Not hard.
would it not be easier to mask off squares and spray white?? as the mirrors already black!
when you say mask off squares do you mean cutting out squares of masking tape and sticking them on?
Or am i being stupid and there being a much easier way :?
