13'' wheel and brake clearance
Hi, will a mk2 golf rear disc conversion fit under 13'' rims? also will i be able to fit ats classics to my 6n, its got the standard vented disc set-up on the front 1.4 8v not the bigger 16v
cheers Alex
  • Views 1.2k
I believe you need 14" wheels to fit 16v brakes, what size are the golf read discs?
sry i ment I've got 8v vented front brakes not the 16v ones, and I'm not sure about the rear disc size but i think there 226mm or sumthing like that
I think they will fit, got rear discs on my car and it has been run on 13s in the past...
ok cheers
thread resurrection.
Right here we go going to use Corrado VR6 rear break's for a conversion.
Only measurment i can find is that they were 226, is this true for the VR6 as well?
Been offered a set of 280's but theres no chance of those fitting on 13's.
rear discs are all 239mm, no matter what they come off. Aslong as you don't have the alloy calipers (as found on mk4 golfs, boras, passats etc) then they will go under 13" wheels
