INTERIOR LIGHTING
Hi there guys, I just bought 3 blue festoon leds and 2 501 blue leds to in my interior ceiling lights.
For some reason some of them stay on permenantly even if the door is closed and the switch is off. And then when I turn them on they are not that bright.
Can anybody give me some suggestions on what bulbs to get and where from?
  • Replies 10
  • Views 1.2k
how do you get in the light to the bulb?
Sorry to hi jack
I know in a mk3 there is a little clip to the right of the ceiling light you have to push to the left with a flat 'ed. should just pop out then.
What do the festoons look like? I've just ordered a 3 LED stripped festoon 42mm for the interior light, sounds like you've got it tapped to the main power feed and when the door opens, the power is absorbed by the other bulb hence the drop in brightness?
For the 6n, Prise the housing out of the roof, unclip the plug, slide back the plastic cover which reveals the bulb, its held in by pressure from the sprung metal, so just push it towards the metal and it will allow you to rotate it enough to come out of the housing. Easier done than said :)
Edited by Polo96CL
Its because when you have the light in the 'turn on when door is open' seting there is still a small ammount of current in the circuit, this is not enough to illuminate the standard filament bulb, but because LED's require less power they still light up a bit. They should get brighter when the doors are opened and more current flows.
I know but is there some sort of bulb that I should get? Like resisted ones. But they still aren't bright when the full current is going through.
Now all the bulbs don't work what so ever :S VERY! VERYYY Confusing!
Any LED strip type bulb with a connection at either end should work. LED's are a diode, so will only allow current through in one direction, if they aren't lighting at all, turn the bulb the other way around. They arn't very bright because they are tiny and low powered.
The thing is, I've replaced my rear ceiling lgiht with 2 39mm blue festoon LED's. If I replace the front ceiling lights with anymore blue LED's they seem to go a bit faulty.
Can anybody suggest any reasons why this happens?
Iv got a festoon led in my car bright white, i paid £13 for just the 1 and its mint never had a problem with its and its bloody bright
Do you mind linking me :D
Yerr no worrys ill find it for you and some people say that its a lot 4 a bulb but you get what you pay 4 at the end of the day, as mine is bloody bright still lights the car in the day light and never had any problems with it.
Edited by Po*Low*
