6N Winter pack
I'm after the winter pack for the 6n - headlight washers, larger bottle, heated screen washers etc. Anyone have the part number/numbers so I could order them? I'd go in to VW and ask but as you know it's hard enough to get them to locate a standard part let alone a rare factory option.
Cheers, Danny
  • Replies 8
  • Views 1.5k
Cheers, Danny
I think the only place you'd be able to get is VW, as it wasn't an option over here, and only available on the conintent.
I figured that but I'm after the part numbers. Are you sure it wasn't an option here? I think it was...
IIRC, the winter pack consists of:
Headlamp washers
Larger washer bottle
Heated windscreen washer jets
Heated mirrors
Front foglamps
We got everything in this country apart from the headlamp washers/larger bottle.
All leccy mirrors are heated anyway aren't they...
So no-one has the part numbers for any of this lot? Mainly the headlight washers..
You could try asking Christian6N. He knows an awful lot about 6N accessories.
I've just had a quick look on vag cat , You have to register ;but its simples. The headlamp washefrs and part numbers are there. Might Help Cheers Mark
Cheers found it :-)
Heated screen washers...191 955 986A
7l washer bottle...2 options...6N0 955 453B or K
Foglights...Left...6N0 941 699...Right...6N0 941 700
Headlamp washers...have 25 parts listed for the complete headlight washer system.
