Boot Lock Problem
Need some help, i cant lock my boot. I know it sounds stupid but i put the key in and it wont turn the lock either way. So how do you lock the boot? Is there anyway i can lock it from the inside???
  • Views 768
umm yeh i think you can, my boot if fucked and wont unlock. if you pull the black plastic cover off (held on with a few clips) you can see the pump and mechanisem and you should be able to see and figure out what is going wrong.
i had this problem mate, try putting the key slightly in and spraying wd40 into the lock and wiggle it, if that doesnt work you will have to take the trim off the inside of the boot and you can open it with your hands, just spray wd40 on the mechanism bit and it should start to turn if not, the mechanism might be fucked itself pal,
sorry i cant help u further
Yer i think the lock has had it so either need a replacement or see if it can be repaired, couldnt work out how to lock it from the inside.
In the end i went to VW and ordered a new lock, will be here on saturday.
