fitting a air filter to a 6n2
NEW QUESTION A FEW REPLYIES DOWN.
I have a 2001 1.0l polo, i have a air filter that i bought, but i am not sure if it fits my car, as i have just seen some panel filter for the same year as my car.
Can anyone tell me if the air filter i bought will fit, any pics of 1.0l polos that have been done with a air filter would be great.
Thank for reading
Edited by lutty
  • Replies 17
  • Views 6.6k
Can anyone help me.
You're going to have to give us some more information. Is it a replacement service air filter you've bought or an uprated aftermarket one (like a cone fillter, etc)?
It is a universal performance air filter, it is a cone one.
It says it fits all standard 76mm pipes, but i am not sur if i have bought the wrong type of filter for my car.
I've got a full K&N 57i induction kit specific to your car available if you want?
I have already got the air filter, but i have also see panel filters for my car, so i am not sure if i bought the right one.
What one do you have for sale.
New Question
Can i fit a performnce air filter to my 2001 polo, if so how do i do it. picks or some advice would be great. what else would i need other than the air filter.
Thanks for reading.
Edited by lutty
I used a pipercross cone, attatching it straight where the old inlet pipe was- it will just about fit! I would advise buying a cotton one instead though as they tend to be a little more durable.
Use a large diameter section of silicon pipe (maybe 2 or 3" long). Attatch this to the inlet and then jam the cone over the other end. you may need to use a jubilee clip to hold it on
You will need to take the manifold apart (engine cover) - take out the standard filters, CUT OUT the elements (cotton bit) but keep the rubber rim intact. This needs to go back in because it forms a seal with the manifold.
Nice one mate, that is a big help mate,
Did you do anything with the cold air feed. where abouts are the standard filters and elemens mate.
Does it make alot of differance to the performance, is it louder then the stock one.
Are you running NOS
Edited by lutty
NOS :lol:
I kept the old feed pipe but its pretty useless because of its small diameter, just hang on to it so you can return to stock.
I'm looking to remove the engine cover and build a new inlet manifold with a ram air system, hopefully next month
i'll keep you posted on that
Its not nitrous oxide, i was running nitromethane fuel additives but it made fuelling very expensive and i couldnt afford to keep it up- so alas no more!
Is the standard filter under the engine cover, where abouts was element you cut out, if not i am sure i will figure out what you mean.
Okay thanks for that.
Yeah mate if you could that would be great. keep me posted
Wow now thats impressive. Bet that was nippy then going have it on when you have built the new inlet manifold with a ram air system. Yeah
Thanks mate been a great help
Are you running NOS
Good one.
I actually lol'd
thats what it was there for! shits and giggles!
did you use a reducer to make it fit, or did it fit striaght on and then you pu the jubilee on.
the silicon pipe i used acts as a reducer, it was an offcut that just happened to fit.
If i were to do it properly i'd use a reducer
putting a filter on a 1.0 :lol:
ino its a GTi - but its a better set up.
To be honest, i would just replace the panel filter with a uprated one. KnN one or something. Cone filter on that isnt going to do very much at all to a 1.0.
  • 8 years later...
If you are looking to change the air filter on a 1.0l VW Polo 6n2 have a look at this video I made.  It's not a straight forward process so hopefully the video will help you out:
