can anyone help me? window problems
hi all, i was going to get my hair cut today and when i parked up and shut my door my window dropped down an inch or so. i have been having some problems with it over the last couple of weeks. so i lifted it back into place, when i shut my door again the whole window (drivers side) dropped all the way in and i cant get it back up. now i can lift it but it seems something is gripping the window at the front so when i do lift it only the back bit comes up and it sticks out diagonaly, its a 1litre so i have winding windows not electrical. does anyone know what the problem is, how i can fix it or how i can take my door cards out (i think there door cards the plastic bit inside with the winder and handle on it)
any help would be greatly appreciated as i have to go to college on friday and the car parks not very secure (they have break-ins about once a month and i doubt a binbags gonna stop them gettin in lol)
thanks in advance
peace
tom
ps i can upload pics of it if needed
  • Views 740
bump to stop people breakin in to my car lol
Ok basically you take the door card off by removing the window winder..the way to do that is there is a plastic ring on the winder which pushes down or up depending on which way it has turned and once popped up/down the winder slides off...
The grab handle on the door card also pops off just use a thin flat head screw driver and pop off the cover the grab handle and behind it are 2 philips head screws so unscrew those...
Take off the mirror cover...
Then pop door card out the whole way around and hey presto its off...
The window may just be off the holder for it to tighten it back up you need to loosen the 2 10mm bolts, place the glass back in and tighten back up again...
Just put the doorcard back on once everything is working again...
Hope this helps..if you want you can upload pics and i'll point everything out...
Benson
thanks so much man il give it ago tommoro
its abit dark to be takin pix now but i kno what u mean
thanx again
peace
tom
no probs best of luck with it..
Benson
