mk4 golf clocks in a 6n
I'm wanting the golf mk4 clocks (the ones with blue lights and red needles)
I'm just wondering which mk4 golfs had theese and will there go straight in my 6n (same style clocks with the petrol and temp gauge at the top)
cheers
  • Replies 12
  • Views 3.3k
cheers
Very much doubt it, the dash isn't just a speedo and a couple of needles like the good old days, nower days they are a complete control unit of there own, including immobilizer and all. If you really want blue lighting and red needles like the golf i would suggest looking into how to change the bulbs, as this would be a lot easier.
I'm not saying its not possible, but just simply stating it would be easier and a lot less stressful to change the bulbs than change the dash unit.
Hope this site helps! :-D
http://www.clubpolo.co.uk/forum/lofiversio...hp/t131878.html
I've got a dash for a 6n mate, it the later style on with the temp and fuel guages in the middle at the top. Its got white numbers and red needles.
Thats what mine is like on this its the updated polo clocks bud :)
lol didnt realise it was you there matty :p, ill let you mess on with yours u can show me it then ill get mine done haha :p
It isnt standard to have white numbers and red needles in a 6n, standard they are green...
hahaha brayson pmsl
do all mk4 golfs have the blue bulbs in the clocks, coz ill just go to salvage yard need get 1, need hav a bash at it
you can buy them off ebay, another thing to note, the wiring is different between the old style and new style clocks... someone will confirm this
hahaha brayson pmsl
If only it was as simple as that mate as i tryed with mine and i have the later style, there was a mk4 golf in my local 1 so toke the clocks out of it,
Got home the loom fits in fine but it does not do any think, i.e no lights no mileage not a thing, the only way i found you can do this is if you have the later clocks you can use the L.E.D's out of the Golf, and fit them to the Polo clocks as I'm half way thow doing this with a spare set of clocks and its working fine, if you have the old style 1s then remove the back and you will see little bulbs well replace them with what ever colour you would like, and remove the green strip at the top and that will sort it
  • 1 year later...
Hi po low, tried messaging you but your inbox is full:) do you still modify clocks ? Looking to go from green to blue in my late 6n.
Ta, Mark.
i have done this fits with slight modification easily done
What put mk4 clocks in polo 6n? Pics?
Mark.
