Polo Noob needing some advice
Hi there just joined knowing nothing about VW Polos AT ALL!
Basically I'm getting a Mk3 Polo 1.0 (think its a 6n?) soon but I'm not sure what to look for. I've found one that I'm going to see on sunday and it says it is a 1999 3dr match, has ABS, Power steering 5 spoke VW alloys. But Is this actually possible as a spec or is it not a match and really something else?
Also any bad things they are notorious for that I should look out for? And are there any good things to look for?
Cheers!
Andrew (Mini 360)
Edited by Mini 360
  • Replies 9
1991 3dr Match with ABS and PAS doesn't sound right at all. Assuming it's not heavily modified, no Polos between 1990-1994 had either ABS or PAS.
And the 6n is 1994 onwards (not sure on the end year)
Something's not quite right! Apart from it being 1991 then everything else sounds like it could be right, although I'm not familiar with the Match spec.
Oops typo! Meant to say 1999!
Ah that sounds much more possible! The year sounds right for a Match, but I don't know what spec they had. Hopefully someone who knows anything about 6ns will reply :-)
Ray
Ray
Thanks mate. It sound pretty good but want to make sure I ask the right questions, look for the right things etc.
my 1996 1.6 polo 6n (which was a 'CL' model) had power steering, not sure on ABS though never really fully checked the spec of it! to be honest i would have thought all 6n's would come with power steering at least, would seem silly to remove it on lower-spec models.
oh, and the 6n is a mk4 polo :) got any plans for it?
Cheers for that. Plans arent too big as its a second car (I must be mad at 18 having two cars :lol:) for when my old Mini is off the road getting new paint and panels done. Once its done may ass dome coilovers and some ATS Classics. But thats well into the future.
Oh and a shameful pic of my main car.... :D
Pride and joy thats getting a few VAG style touches added to it when its getting redone.
hi mate thats a well nice mini you got there, tecnigal it is a mk3f but most people call them mk4's , there was a topic on here a few days ago about the diffarent mk's of polo's. the 1l engines are pretty bullet proof but slow, 6n's suffer from rust on the arch's and seals so check for that. I thought that the 1l were the only ones in the range to not have abs or power steering but maybe there where factory options if the person that really wanted a higher spec 1l, or maybe they came standered on the later 6n. 6n's were made between 1994-1999 in spain. so yours could have been one of the last ones made and vw may have put abs & power steering as standered then I'm not to sure.
james
It's not technically a 3f, it's technically a Mk3, as what we call the mk3 on here is actually a mk2f.
Just call it a mk4 / 6n :-)
Oh and welcome by the way, hope you find the forum useful.
Thanks guys! thats really helpful! Will see when it comes to test drive if its got what it says it does. I'm only 18 soooo 1L is for insurnce reasons. Plus I dont want to go back to the Mini which is also 1L coming from a more powerful 1.4 etc.
