Polo GT parts for conversion
Hello
I need these parts for a GT conversion for a Mk2:
Polo GT Digifant ECU and its wiring
GT fuel pumps and any mountings or wiring
GT exhaust manifold (4 to 2?)
GT Throttle Body
GT inlet manifold, fuel rail etc
GT fuel tank
I'm in Wiltshire, and I don't mind paying a fair bit for postage. :-)
Edited by anessen
  • Replies 11
i've got an ecu....
Loom Here! And GT Manifold.
Got the wiring and manifold, cheers!
i have a set of injectors
Hello
GT Throttle Body
GT fuel tank
hey, i have some gt bits, i have the full front loom, injectors and rail etc, standard air intake system....
i put the gt lump into my golf but decided to run carbs instead so its all just sitting there.
if your interested ill get some photos or send you some via multi media message on your phone. i'd like to see £50 for them so i can get the fuel pump i need. ill also get them weighed up for postage if you cant collect.
I'm based in harlow, CM18 and if need be could meet you some where
ben
07961250946
I have a GT pump and all the bits (still on the car) also have a GT rail with GT inectors. PM if your interested.
I have a GT inlet manifold with fuel rail. drop a pm if u r interested
you dont need a gt feul tank you just need a feultank off of a polo thats feul inj they all have pick up pumps fitted to them
the feul inj polos have the mounts and wireing for feul pumps
i could sort you out with a interior wireingloom with feul pump wires a lift pump and feul pump mounting thing
pm me si
sorry no offence to any one but you dont need a fuel injection tank you need the primer pump from the tank not a lift pump as there part of the engine. with out the primer pump the main under car pump will burn out due to lack of fuel.
got a choice of 3 fuel tanks 2 GSF 1 vw all good usable condition (£15 each plus postage likely to be about £15) and the bracket that holds all the injection parts up next to the rear wheel well with the wee accumulator and brackets £10. and got an inline pump done 74K (£38 posted) Also got fuel lines and intank pump if you need them.
got a few Throttle bodies. pm me dude.
might even have am ported/polished one
