8v Rear Bumper
I am removing the rear bumper from my 8v 6n. I have taken out the 2 screws in each wheel arch and the 4 that go across the boot. However it doesn't seem to watch to budge and seems to be stuck at the bottom of the top half? The Haynes manual says only the screws I mentioned need removing then it should slide out?
Any ideas what the problem is?
  • Views 1k
Theres one in the middle at the bottom of the top half of the bumper to mate, its a 10/13mm bolt. After that pull it with abit of force, not to hard though unless you've unplugged the number plate lights.
