How do i get my centre console out my 6n?
as title says really,
thanks guys
  • Replies 9
  • Views 1.4k
if you mean the whole bit around the gear stick?? where the slot is , (where you chuck money and stuff in front of the gear stick) there shoulod be some screws 2 at the top i think, then undo the gaiter around gear stick and there should be 2 plastic bolts holoding it down,,
thats all i remember mate
sorry mate i mean the part that goes round the headunit and the dials etc.
the main bit
ahaha sorry that bit i dont know mate, can you not pull the dials all off and then pull it off, or take cd player out and see if there are any screws??
ok so take the head unit out, pop the top vents off with a flat blade screw driver, then theres 2 phillips screws, then under neath the console (behind ashtray) theres a few more screws, then pop the heater dial surround cover and unscrew all that, job done
pop the top vents off?
sounds confusing?
how do i do that mate?
^^^ there you go pal, top help!!
^^^^ one more question, haha
the two vents need to be pushed at the bottom so you can fit a small flat blade in the gap and pry them off!
Or you can put a flat screw driver in the endge of it.
You will also have to take you heater controls out i think.
