Door Jammed Shut (MOT soon)
Help!
i have a 6n2
shortly after buying it the key barrel broke on the passenger side. i thought i would have to buy a whole new barrel. which at the time i didnt want to do. so i left it. a few weeks later and the the door wouldnt open. nothing. just jammed shut.
Then after about 2 weeks it just randomly worked again. Took the door card off. and everything is in place. and working. so i just forgot about it.
since then it will work fine for ages. then one day not work again.
sometimes opening from the inside works.
sometimes the outside
sometimes locking and unlocking the cars works.
the other day i was doing a random search on eBay and found a key barrel fix kit.
which pictures the exact bit in the barrel that broke. i thought great ill buy that and fix the barrel!!!
but now the doors stuck again.
and its been stuck for about a week now.
i can deal with having my friends and family sit in the back.
but i have my MOT soon. and the door working is an obvious fail
i obviously cant get the door card off with the door shut.
and i cant yank the door. because i noticed the other day the handle (the part where the barrel is) is attually coming away from the door
any suggestions to getting it open would be greatly appreciated
go on! anything at all!
thanks in advance
  • Views 2k
the best bet would be doorcard off and try and unhook it yourself from the hinge mate, but i dont know how hard it will be to get doorcard off with the door shut
I reckon you`ll have to kill your doorcard buddy, at least a knackered doorcard isn`t an mot fail.
arite lass! its pretty easy (but time consuming) what you need to do is undo the bolt under the front of the seat and then slide it all the way back to take it out, then undo the doorcard, pull it out as carefully as possible (it is possible believe me, its very fiddly though and the door card might bend abit) then put your hand inside the door by the lock mech and pull the lock rod up and get soemone to pull the handle on the outside, if this doesnt work then wiggle all the lock mech but and it should eventually come open!! mine did this to me just before i converted to delocked handles and then i had to do it again, when my central locking stopped working in the door all because i have flush door pins!
Edited by Pepe
thank you so much for that!
gonna give it ago this weekend as I'm off work and giving the car a good clean and re-painting the brake calipers anywho.
ill let you know how it goes. wish me luck!...and that i dont make it worse lol
Alas! I've had no luck
took the door pin off and the screws under the interior handle. and pulled the door card back as far as i can. i can pretty much see the whole locking mech from some angles.
I've pushed and pulled and fiddled and wrigged and still no luck :(
still I've left the door card hanging off and will get the bf to look at it. hes got a way with working car stuff out.
Ah sorry bout that, have you tried a pair of pliers on the door pin rod where you unscrewed it and give it a good solid tug an try hold I as far up as you can and get someone to open the door?
Thin nose pliers would work best!
thanks for the help pepe
finally got the door open :)
yep took it all apart lol
finally i think a long screwdriver to the mechanism got it open (i went inside the house then the bf called me and taadaa it was open)
dont want to go thru all the stress again. so I'm not shutting the door. got to order a new part
annoying the part number was very very well hidden. so by the time i found it the part on ebay had gone :(
only £10 on ebay
annoyingly £30 from a breakers
and £113 from VW (yeah wtf)
