mk3 GT coupe
well its a bit of a sorry state at the mo but heres my gt. had it about yr n half after buying off a mate with a hankering for a suzuki sj! already had susp with adjustable rears like philj kits, exhaust, de badged grille clear ind and 15inch team dynamics multi spokes . I swapped these for 14inch alfa revo's on 195/45 :-D (facoured this setup) with matt centres and it looked respectable with arch/sill trims and i was content :lol:
new top mounts and golf master and copper re-line. engine wise it got top end refresh and t/belt all fluids an filters,plugs, blue temp, loom re-taped, golf gti afm + k&n, de-wedged tb and i rebuild the correct dizzy (p) with hall sender from cl! you can see the forum faq influence so cheers guys who knew all that, invaluable!
Next up I de catted it, looks almost factory!
  • Views 1.3k
shotblasted backplates and the tank and axle got a coat for winter :roll
http://i825.photobucket.com/albums/zz177/g...10/CIMG2051.jpg
It now sits on steelies awaiting me to weld the sill/floor :crybaby: what happened here i think was dropping off a kerb in a low car dents sill=rot creep in and has it crept! front trims bent but you can get these separate so not all doom n gloom. the n/s sill is fine and a pretty clean genuine gt so I want to get on with it and not break it! theres alot of tidy cars about here so i need that push to get it done then a few more tweaks!
<a href="http://s825.photobucket.com/albums/zz177/gtcoupe2010/cpolo/?action=view&current=CIMG2040.jpg" target="_blank"><img src="http://i825.photobucket.com/albums/zz177/gtcoupe2010/cpolo/CIMG2040.jpg" border="0" alt="Photobucket"></a>
http://i825.photobucket.com/albums/zz177/g...lo/CIMG2040.jpg
http://i825.photobucket.com/albums/zz177/g...10/CIMG2050.jpg
http://i825.photobucket.com/albums/zz177/g...10/CIMG2063.jpg
http://i825.photobucket.com/albums/zz177/g...10/CIMG2062.jpg
Also got a pair vw2 calipers bonnet struts and gti coil mod to go on and so far one ten hole 14inch vento steel, hmmm uni-polo wouldnt work?!
http://i825.photobucket.com/albums/zz177/g...10/CIMG2053.jpg
Pics are poor atm and I cant upload the rest to go with this text? I'm halfway through loads of little jobs on it but hey il get some more pics sorted if theres any interest. jst edited hope that wrks
Edited by ..beat.box..
Use the [img/] tags to embed a picture in a post :thumbsup:
