Polo 6N2 GTI Clock's
Hi Guy's
I've just managed to get myself a set of 6N2 GTI Clock's/Speedo with the centre Piece and The Piano Black surround for £50 including Postage on Ebay!
I was wondering how do you remove the old one's to replace them with the new ones?
Regard's Mr Polo
  • Replies 17
  • Views 4.7k
mini torx bit thing,
look under the cover, you'll see some screws and start from there.
in fact, look on the ones you've bought and see where the screw holes are.
Hi
Thanks, I see the one under the Clock Cover, and that's about it :S
I'm a total novice really, I'm not too sure where to start i don't want to break anything :-)
Does anyone know some step by step guide's? I've looked all over the place to no avail :(
Regards Mr_Polo
at a push, use the FAQ's on club lupo, find the one about dash removal.
remember, the top bit is in two pieces.
Hey
thanks again for your reply but I still cannot find anywhere, instructions on how to remove the clocks :( I checked Club Lupo but didn't find anything, I've been picking my brains all day trying to figure it out hmmm
Edited by Mr_Polo
Bump...
I've said it once, i'll say it again.
there's a screw under the thing, use your hand and feel for it.
Yes I've undone that screw as it's the only one I can see, is there a way I have to slide the surround for one half to pop off?
just pull on the top part.
I just had a play with my mother's lupo GTI so I know I'm right.
plus mine once looked like that inside.
I'm looking to do the same thing, as my clocks are playing up, I too have undone the screw in the cover, but it doesn't seem to loosen anything really, I'll keep playing.
But let me know if you manage anything.
Hey
I finally managed to get mine off today :)
You undo the one screw and either Pull on the strip (You can see the line across the top to the side's) or try and get a screw driver underneath the piece as there is about 4 clip's holding it on. Be careful not to scratch it though or snap it :) Eventually it pop's off. I'll upload some pic's to give you an idea :)
Best of luck.
Not sure if these Help or make any sense, Hopefully they'll give you some idea. Sorry about the quality :)
Edited by Mr_Polo
Crackin' mate, I only bought my 'loon 2 days ago, so I'm scared to death of snapping/cracking something, will give this a go tomorrow, am I right in thinking you slide the back part away from the front band?
Cheers. :)
Hey
I just got a screw driver in the end to separate the band from the big part, Unfortunately i scratched it a little (You might be able to see) I didn't mind as I've got a new one coming but was still annoyed of course But it came off eventually, Maybe it's easier for others....
The Band just comes off and then there's two torx screws to undo, I'm sure you'll see them :)
Edited by Mr_Polo
are these sealed units? because I've got some dirt at the bottom of my rev counter inside and its bugging me!
My airbag light keeps popping up now and again and i want to stop seeing it.
I have taken out whole dials unit on my 2001 polo 1.4 i want to cover up the Airbaglight with tape but how do i get to the bulb?
do i open from the back (white case) ?
help!!!!
