My sandblasting cabnet
Ok so I finally set out to make this sandblasting cabnet,
All the wood and perspex lid cost about £70
abrasive media £20 for 7.5kg
and £20 for the sand blaster.
17" Marigold's £10
oh and a day off..
Ok so its works and the cabnet does its job well!
But! I don't think my compressor is powerfull enough.
The flow of sand being blasted is not constant or powerfull enough, but it does take paint off when it wants to work.
Can anyone shed some light, I don't want to buy another compressor so I guess I need to sell this £100 will do, for the cabnet, abrsive media and blasting gun.
Edited by iDan
thats pretty cool! the black pipe, does it just sit in the sand?
Is it one of the grey plastic sandblasting pots? If it is, you need a huge compressor to make them work. The guns with the pot under the handle you can get in machine mart are way better, you just have to fill lthem more often.
Yeah the pipe just sits in there, with a metal sython pipe to hold it under the sand. Then it goes bk down the white pipe into the bucket.
No its not gray yeti, its brown, aluminum abrasive media, is what it says on the tub :D
Nah, thought you'd bought the same crappy blaster as I did. I'd try running a horizontal feed out the bottom of the pot, maybe getting gravity to help you, but if it's owt like my old setup, it's a losing battle.
use a leaf blower with a funel to consentrate power
Yup the gravity feed will be my last option before selling it. what was wrong with you are setup? and what were you using yours for?
