door seems to have dropped.
my door seems to have dropped as it sits different so i have to slam to make it shut, is there any way of fixing this?
  • Views 841
May sound stupid but just check the two bolts are tight that hold the door on.. also make sure the hinges look alright!
will give it a try :D
my micra has done this, if its what i think you mean, then with old age it has sagged downwards.I just gently pulled the door upwards, holding it from the bottom where the sill is. worked fine after that.
Max
